A/CL : Air Cleaner Vacuum Control Valve
A/CL CWM : Air Cleaner Cold Weather Modulator
A/CL Bi-Met : Air Cleaner Bimetal Sensor
A/CL DV : Air Cleaner Duct Valve Vacuum Motor
ACV : Air Control Valve
Air BPV : Air Bypass Valve
Anti B/F : Anti Back-Fire
CAT : Catalyseur
EGR : Exhaust Gaz Recycling
IVV : Idle Vacuum Valve
LCV : Load Control Valve
MAN VAC : Manifold Vacuum
PCV : Positive Crankcase Ventilation
Purge CV : Purge Control Valve
SA-FV : Separator Assembly-Fuel/Vacuum
SOL-V : Solenoid Valve
SV-CBV : Solenoind Valve- Carburetor Bowl Vent
TVS : Thermal Vacuum Switch
TVV : Thermal Vent Valve
VAC : Vacuum Advance Control
VACVV : Vacuum Vent Valve
VCS : Vacuum Control Switch/Solenoïd
VCV : Vacuum Check Valve
VCKV : Vacuum Check Valve
VDV : Vacuum Delay Valve
VOLTM : Vacuum Operated Load Throttle Modulator
VOTM : Vacuum Operated Throttle Modulator
VR/S : Vacuum Regulator/Solenoid
VRDM : Vacuum Retard Delay Modulator
VRDV : Vacuum Retard Delay Valve
VRESER : Vacuum Reservoir
VVVac : Vaccum Vent Valve
Ce message a été modifié par TuxStang - 21 June 2009 - 07:28 PM.
