#261
Posté 30 October 2008 - 11:55 AM
Posté 30 October 2008 - 12:19 PM
#263
Posté 13 December 2008 - 04:57 PM
*Tachometer, Auto Gage, 0-8,000 rpm, 5 in., Analog, Electrical, with Shift Light, Each
*Clutch Kit, Dual Friction, 1 3/8 in. Diameter Shaft, 10-Spline, 11 in. Diameter Disc, Ford, Kit
*Throwout Bearing, 1 1/16 in. Shaft Diameter, Jeep/Ford/AMC/Mercury, L6/V8, Each
*Brake Pads, Redstuff, Ceramic, Front, Ford, Mustang, Set
*Valve Covers, Stock Height, Cast Aluminum, Black Wrinkle, Ribbed with Cobra, Ford, Big Block FE, Pair (pour battre Romu)
*Shifter Installation Kit, Competition Plus, Top Loader, 433, Ford/Mercury, Kit(avec une troisieme)
*Manual Shifter, Competition/Plus, Ford/Mercury, Passenger Car, Each
*Air Filter Assembly, X-Stream, 14 in. Diameter, Round, Ribbed Design, 2 5/16 in. Filter Height, Each (genre charlotte framboise)
*Lug Nuts, Conical Seat, 45 Degree, Double End, 1/2 in. x 20 RH, Open End, Natural, Steel, Set of 5 (pour les sliks
*Starter, Mastertorque, Mini, Ford, 390/427/428, FE, Each
*Axle Seal, Ford, 9 in., Each
*Ring and Pinion Installation Kit, Ford, 9 in., 3.062 in. Carrier Bearing, 28-Spline Pinion, Kit
*Carburetor Spacer, Phenolic, .500 in. Thick, 4-Hole, Square Bore, Each (charlotte trop haute pour un 1")
*Driveshaft Safety Loop, Bolt-On, Adjustable, Black Powdercoated Steel, Universal, Each
deja ça devrait me faire un BOKDO pour mon noel
Posté 13 December 2008 - 05:28 PM
Manque plus que la boite de Banania
#265
Posté 13 December 2008 - 11:35 PM
Bon, d'un autre côté j'ai un trou dans le capot et pas de charlotte (pas encore
#266
Posté 14 December 2008 - 08:34 AM
Belle liste et joyeux noel
Posté 17 December 2008 - 11:57 AM
Posté 17 December 2008 - 05:53 PM
#269
Posté 17 December 2008 - 09:34 PM
mais c'est vis a vis de Romu ,j'voudrais avoir trop de canassons sous le capot pour l'année prochaine,c'est pour ça que j'ai commandé les memes que lui
Posté 17 December 2008 - 10:06 PM
je sais,je sais,
mais c'est vis a vis de Romu ,j'voudrais avoir trop de canassons sous le capot pour l'année prochaine,c'est pour ça que j'ai commandé les memes que lui![]()
si romu lis ça sa sent la revenche sur un drag strip ça ou a la buvette
je suis impatient de le voir ça peut etre interessant
#271
Posté 17 December 2008 - 11:10 PM
commande est passée,je passe ce soir chez le rectif pour recuperer mes tambours
Tu aurais pu économiser sur les freins avant et arrière et te payer un vrai "petit" moteur
puis des freins, t'y vas pas pour freiner quand même
#272
Posté 17 December 2008 - 11:48 PM
ça va me laisser de la marge pour bouffer du coco sur le circuit
Posté 18 December 2008 - 01:10 AM
je prevois pour le MD pour le freinage ,suis à quand meme 40 km du circuit MOI!
Ah houai................................................les plaquettes ROUGES !!!!!!
#274
Posté 18 December 2008 - 05:27 PM
#275
Posté 18 December 2008 - 09:05 PM
si tu freines pas, c'est que t'avance pasDe toutes façons, si tu freines t'es un lâche
je sais,je sais,
#277
Posté 04 January 2009 - 11:11 AM
ma commande est toujours en attente chez mickey,il sont peut etre bloqué par la neige
j'ai pourtant envoyé un message pour qu'il supprime le back order sur une piece,il me reponde que c'est ok et que les autres pieces sont dispo et partent dés que possible,depuis toujours rien
je crois que je vais leur repasser un mail en franglais,pour savoir si ils se bougent un peu le c**
Posté 14 January 2009 - 11:43 AM
Posté 14 January 2009 - 11:20 PM
achat d'un Main Girdle pour une futur modif
Bon début, moi ça fait 1 an que j'amasse les pièces
Ce message a été modifié par nicolas - 14 January 2009 - 11:21 PM.
#280
Posté 15 January 2009 - 11:07 AM
enfin faud je j'envoi le paiement semaine proch.
