Question Clac-Clac Moteur
#121
Posté 26 July 2011 - 12:47 PM
Isky
Restore optimum levels of zinc/phosphate to your motor oil with ZDDP Plus. ZDDP Plus is an oil supplement that contains very high concentrations of the well-known additive ZDDP (zincdialkyl dithiophosphate), which has been the primary EP (extreme pressure) ingredient in all quality motor oils for over 70 years. With the stricter emission requirements on new cars, manufacturers have removed ZDDP from motor oils. If your older car was designed to use SF or earlier motor oil, it requires ZDDP, because your engine could be damaged with the use of modern SM oils. If you have a race car that runs a flat tappet mechanic or hydraulic lifter cam, then your engine is at serious risk. ZDDP Plus can be used with regular and synthetic oils. Simply add it whenever your oil is changed.
Comp Cam
COMP Cams Engine Break-In Oil Additive brings back the good stuff, delivering a specially engineered blend of extreme pressure break-in additives that have been removed from current off-the-shelf motor oils. Delivering added protection during the break-in process and beyond for all engine components, including the camshaft and lifters, COMP Cams Engine Break-In Oil Additive is compatible with any petroleum, synthetic, or blended motor oil. COMP Cams Engine Break-In Oil Additive extends the durability of internal engine components, protecting against premature camshaft, lifter, and valvetrain failure. Best of all, COMP Cams Engine Break-In Oil Additive has been proven to deliver long-term benefits with new or rebuilt engines through continued usage. Simply pour in a bottle for the initial break-in, run the engine for approximately 1,000 miles, drain the system thoroughly, and then refill with clean oil and another bottle of COMP Cams Engine Break-In Oil Additive at each oil change
Trick Flow
Trick Flow® Engine Oil Supplements provide added protection during the critical break-in process of your fresh engine. Specially designed for flat-tappet camshafts, Trick Flow's engine oil supplements have been formulated with the latest anti-wear additives for extreme pressure protection. Designed for use with conventional motor oils that lack the necessary zinc, phosphorus (ZDDP), and anti-wear additive packages, these oil supplements are necessary for protection against excessove camshaft and valvetrain wear. They can even be used with every oil change for the ultimate in protection against premature valvetrain wear.
Brobrok
Does your engine need a little boost? Edelbrock high performance engine oil supplement with zinc additive should do the trick. Designed for hot rods, sports cars, musclecars, and exotics, this oil additive is specially formulated from zinc, phosphorous, and moly, creating the ideal nutrients for added wear protection of your engine's oil. It won't rub, scrape, or wear off, so it's perfect for cold starts and infrequently driven vehicles. Extend engine life and increase mileage and horsepower with Edelbrock high performance zinc additive
Crane Cam
Crane Super Lube Break-In concentrate is an anti-wear additive formulated with high concentrations of special zinc dithiophosphate to provide sustained protection against cam lobe and lifter scuffing and wear. This oil supplement is to be added to the engine oil for the initial break-in period after the installation of a new camshaft and lifters.
Sinon il y a d'autres sorte d'additifs a base de moly ou de silice et meme une nouvelle molecule qui semble interessante, le Triboxyl. De la a dire que ca remplace completement le zddp, j'en sais foutre rien. Perso, j'ai toujour recommandé le mecacyl dans mes moteurs et jusque la ... ca va ...Certain fabricant font aussi des efforts pour traiter les poussoirs et les aac, mais il conseille toujours d'additiver, donc c'est que c'est pas encore vraiment au point ...
#122
Posté 26 July 2011 - 05:17 PM
#123
Posté 26 July 2011 - 05:33 PM
#124
Posté 26 July 2011 - 06:12 PM
'FomocoJL', on 26 Jul 2011 - 4:17 PM, said:
Pourquoi, t'es pas satisfait de ton additif patajoint ?
et le Botox, ça peut remplacer le Triboxyl pour les micro fissures ?
Avec les rollers, il ni a pas ce genre de probleme (encore qu'avec les aac en fonte ...), les rouleaux des lifters petent avant les aac
#125
Posté 26 July 2011 - 07:19 PM
'Sponge', on 26 Jul 2011 - 4:33 PM, said:
Sur un roller hydro, comme y pas de rôdage, l'additif est préconisé? Je préfère demander car sur un moteur à + de 10 000€, on est pas à 20€...
Même pour 10x moins on est pas à 20€
#126
Posté 04 August 2011 - 03:54 PM
j'ai reçu aujourd'hui mon moteur Choppy remanufactured - j'avais aussi un tak-tak inquiétant qui faisait penser soit aux poussoirs et/ou un jeu au niveau d'un piston - de fait, il est arrivé avec une notice "super engageante" où il est écrit en lettres capitales :
- CAM BREAK-IN ; IMPORTANT NOTICE: YOU MUST BREAK IN THE CAM CORRECTLY USING THE CORRECT "ZINC" OIL OR THE ENTIRE ENGINE CAN BE RUINED! READ YOUR "BREAK-IN" AND OIL INSTRUCTIONS VERY CAREFULLY!!!!!!!
- NOTICE: THIS ENGINE MUST ALWAYS USE HIGH ZINC CONTENT SPECIAL GRADE OIL USE .14% (1400 PPM) ZDDP OIL TO PROTECT THE CAM & LIFTERS FROM BEING DESTROYED WHICH WILL COMPLETELY RUIN THE ENTIRE ENGINE!!!!!!! USE "CLASSIC CAR MOTOR OIL" AVAILABLE FROM US OR ON LINE!!!
Sympas, ils m'ont mis dans la caisse : 1.5 OZ ADDITIVE ZDDP 1 SHOT et de L'OIL BREAK-IN 15W50.
Ca confirme 1. le rodage nécessaire et 2. le ZDDP incontournable. Je ne leur ai pas demandé s'ils avaient refait pour une utilisation sans-plomb.
Cdlt,
MadMax
#127
Posté 04 August 2011 - 04:29 PM
#128
Posté 01 September 2011 - 01:17 PM
Je ressort le bloc de l'auto pour le nettoyer complètement et repartir sur une très bonne base
#129
Posté 12 September 2012 - 04:40 PM
Pour les bruits à froid des poussoirs, je n'ai aucune idée de là ou ça provenait. Ca ne le faisait uniquement à froid pendant 5 minutes et moteur en charge (pas au ralenti).
Ceci dit le moteur tournait très bien et était réactif etc.... Dans un pêché d'aller chercher la petite bête, j'ai voulu changer les 16 poussoirs hydro, opération que j'ai faite réaliser chez un pro. Qui n'a pas fait la procédure de rodage d'acc, qui je pense n'a pas graissé les paliers et qui n'a sans doute pas mis de zddp et qui de succroit n'avait pas fait de repère sur allumeur/pipe et m'avait remonté ça de travers.... Donc 16 poussoirs (de qualité) à changer et un ACC bien sûr autant ne pas faire les choses à moitié (avec bruit violent de poussoir mais au chaud donc autant dire, tout le temps
Depuis j'ai tout remis en place avec un connaisseur soucieux de faire du bon boulot sur une auto qu'il apprécie. Changement ACC + poussoirs (toujours de qualité) + zddp + procédure de rodage respectée est là : tout va mieux ! Et tout va bien dans le meilleur des mondes.... Jusque quand ? je ne préfère pas le savoir, on verra et on avisera, mais restons positifs....
Si tu as de l'huile qui contient du zddp, utilise là. Si tu as un léger claquement à froid, ben laisse chauffer l'auto avant de rouler mais surtout laisse tout en place. Perso si c'était à refaire et bien je ne le referai pas et je laisserai comme c'était.
#131
Posté 14 September 2012 - 06:09 PM
J'ai changé mes poussoirs sur mon 289 stock début août et j'ai bien dû faire 500 bornes depuis.
J'ai juste changé les poussoirs et j'ai pas mis de produit miracle.
J'entends un poussoir chanter à froid quand je démarre pendant quelques secondes puis après, plus de bruit.
Dois je mettre une fiole de zd...machin ou c'est trop tard?
Y'm' fait peur ce post
#132
Posté 14 September 2012 - 06:39 PM
As tu procédé a un rodage?
#133
Posté 14 September 2012 - 06:54 PM
#134
Posté 14 September 2012 - 08:32 PM
Comme le moulin est d'origine, je me suis dit autant mettre des poussoirs neufs et les regler comme il faut.
Je ne me suis pas préoccupé du rodage, je ne savais même pas qu'il fallait les roder avant de tomber sur ce post, d'ou mon inquiétude
#135
#136
Posté 14 September 2012 - 08:50 PM
#137
Posté 14 September 2012 - 08:53 PM
Je dois faire quoi maintenant? Prier pour que tout se passe bien?
#138
#139
Posté 14 September 2012 - 10:15 PM
#140
Posté 14 September 2012 - 10:38 PM
Au contraire moi mon soucis c'est que plus le moteur est chaud, plus ça claque, ça doit être moins bon ça!????!
